2x portrait + 1x landscape in eyefinity
25 Sep 2010
So i just borrowed 2x Dell 19" screen from a friend to try in portraid mode along with my 26" Samsung T260, thats in middle in landscape mode.
It works perfectly fine when in extented mode, but when i try to activate eyefinity mode in CCC the 2 Dell monitors switch back to landscape, and i can´t do anything about it once it activated.
I know this is possible i´ve seen videoclips on youtube :p
anyone know how to fix this?
Slightly off topic, but how did you get your monitors to work in portrait-landscape-portrait in extended mode? I'm trying to do the same thing (T260, and 2x19") however it doesn't give me any option to rotate my monitors once I plug a third monitor in. What card are you running, and which driver version?
I´m guessing you arent using the display port, i´m using an active displayport ---> dvi
These adapters are expensive, but a must to if you wanna use 3 screens at the same time. 2nd option is to use a monitor that supports displayports.
You can't do eyefinity with portrait landscape portrait unfortunately. Also, displayport adapters aren't that expensive now at about £20 or less.
I am, it's only one of the single-link DVI ones though, don't know if that makes a difference, but it's fine in portrait when there's only 2 monitors connected, and I can run all 3 fine in landscape in extended.
