I’m looking at a prebuild that comes spec’d with this memory by default – which I quite like price/performance wise and the black with RGB ties in with the ASUS Rog Strix Mobo and 1080TI:
https://www.overclockers.co.uk/team...al-channel-kit-rgb-black-tf1d4-my-08m-tg.html
However one of the config options for the prebuild offers a single 16gb DIMM from Build Stock (I assume that means a spare single they have left over from a previous build). It’s 3000MHZ so slightly lower speed but from what I read that’s not a massive difference anyway. I believe it’s one DIMM from this kit:
https://www.overclockers.co.uk/team...ual-channel-kit-grey-tlgd432g3-my-08p-tg.html
Using that would knock off £100 from my build. The timings look identical. Assuming that OCUK would honour their life time warranty it seems like a no brainer (other than losing RGB but I suspect the novelty of that will soon wear off). But is there any issues, performance or otherwise, running a single DIMM rather than a pair? Possible later down the line I could add more – would I be able to do that as 2x8gb or would I need to stick with the same type in all slots for best performance (which would mean another 2x16GB)?
Thanks in advance.
Thanks in advance.
