Having trouble hitting 3.2 on a P5Q motherboard. Using a corsair A50 with 2 corsair fans in push/pull. 3ghz is fine in 1.25v but I can't get 3.1ghz on even 1.275v
Edit; I have set DRAM Voltage to 1.8 and set the ratio so that it stays below its rated speed (800mhz)
Should I adjust the PLL voltage at all? All I have changed it FSB, Enabled LLC, CPU voltage, DRAM ratio and Voltage
