Not sure if I should be posting this in the GFX or Monitor board so apologies if I've posted in the wrong one.
I currently have a single MSI 560Ti ( Link ) which is connected to my 32" LCD TV (currently wasting the 560 on HTPC duties). I'm wanting to start using the PC as a proper gaming rig (mainly for FSX) so am looking into getting three 23/24" monitors. I'm thinking about getting 120hz panels so I can enjoy some 3D but I'm unsure if this would be possible with the current GFX card I have. I understand I will probably not be able to run three monitors from a single card and was thinking about getting another 560Ti and running it in SLI (if that's possible with a 3 monitor setup).
Will two 560Ti's work with 3 3D monitors? I take it 3 monitor 3D setups are possible using the Nvidia 3D vision? What are the best (and cheapest) screens that will do the job ok? It's actually quite hard to find a 120hz monitors through normal searches and I've noticed a few 60hz ones that have their own 3D setup (how 3D would look at 30hz per eye I dread to imagine
). I'd also prefer 1980x1200 instead of 1980x1080 although I've not found anything at this size that doesn't cost the earth
. So far I've found the following that take my fancy:
Anyone recommend one of these monitors or are there better ones out there for about the same money? Ideally I'd be looking at spending no more than £250 a monitor but could possibly go a wee bit higher
. Lastly I'd rather the monitors were VESA compatible but this isn't a major demand and more of a preference. I know the XL2420T (and probably the 410T) are not VESA compatible. Thanks in advance for the help.
. So far I've found the following that take my fancy:- Samsung S23A700D
- Benq XL2410T
- Benq XL2420T (although I don't really need the "gamer" features but the USB would be useful)
