3.3v rail randomly going low after a period of use.
7 Jul 2016
I am having a recent problem with my PC.
After a "random" amount of 100% stable running time (anything between 1 - 12 hours), the 3.3v rail will suddenly start dropping step-by-step from 3.36v to approx 2.8-2.5v over a period of 2-4 minutes. The machine then simply resets and reboots - but is then "good to go" for another random amount of time.
Although I know software monitors/loggers are not 100% reliable, I have logged the voltages using Asus AISuite, HWMonitor and HwiNFO and all show the same drop on the 3.3v rail just prior to the reset.
The 12v and 5v rails are rock solid throught the entire log - even when the 3.3v rail is falling.
The tempratures of case, mobo, CPU and GPU are all well within limits.
The fans seem to be doing their jobs.
Apart from the 3.3v drop everything else seems to be fine - even during the "final minutes"!.
This can occur at any time .... while simply using a simple text editor or running Grand Theft Auto V (as I did yesterday for 3+ hours without incident - then back to desktop, 30 mins later "reset")
If anyone can give me help or advice, I would be very greatful.
TIA
MB : Asus P8Z68-V PRO GEN3 (LGA1155)
CPU: Intel Core i7 2600 @ 3.40GHz (no overclock)
RAM: 12GB Corsair Venegence DDR3 (no overclock)
PSU: 1000W Coolermaster "Silent-Pro"
SSD: 256GB SanDisk Extreme Pro SDSSDXPS240G
SSD: 128GB OCZ-VERTEX3
HDD: 2TB Hitachi HDD HDS723020BLA642
GPU: NVIDIA/EVGA GeForce 4GB GTX 970 (factory overclock)
All other peripherals KB/Mouse/WebCam/2xHDD are connected to an externally powered Anker 60W 7-Port USB 3.0 Data Hub
Hi and welcome to the forums. :)
It does sound like the psu is at fault. Ideally you need to test with a multimeter. I would stop using it. Is it still under warranty?
I figured out how to use the DMM !!!!
Many thanks for your replies. I have checked the rails with a DMM (observing each rail for 2 mins):
12v: Min: 12.10v Avg: 12.10v Max: 12.12v
5v: Min: 5.10v Avg: 5.10v Max: 5.11v
3v: Min: 3.40v Avg: 3.40v Max 3.40v
These figures compare VERY closely to the on-motherboard sensors - maybe 0.02v difference between them.
Strangely, my machine has been up for over 14 hours now - nothing unusual going on .... I am just logging and waiting for that 2 minutes where, step-by-step the 3.3v falls!
