My CPU fan has a 4 pin PWM header, so that should mean I can easilly plug it in to the male 3 pin connector. I am pretty sure you can use a PWM fan on a 3pin connector as it has the 3 pin "mounting" built in to it.
What about the actual power cable itself to power the fan controller? Is that quite long too?
Sod it, ordered two of these + 2 Scythe Kaze Jyuni 1200RPM 120mm fans. I like the idea I can turn off 2 of the fans (so all 4 of my case fans if I want), something which will come in handy in the winter
