Yes, the side holes are the same so I guess a 5.25" to 3.5" hard drive mount will work?I'm presuming the holes on the sides are in the same location as the moved one on the bottom? Or are they in the original places?
I have tried 2 screws (one on each top side) but it is unbalance/wobbles and there are no screw holes in the case (Silverstone ML03) that fits any holes on the drive.Can you not just use the two holes nearest the connectors ? As long as you can secure it with a couple of screws it will be fine.
