I have a NAS server and need to add a few more mechanical drives, but the standard drive bays are used.
Now, there's space at the bottom of the case, and my intention is to find\fabricate a pair of brackets that can hold 2x 3.5" drives each (so a pair of drives stacked in each bracket, with two brackets side by side). The bracket will be attached to the bottom of the case. There is maybe 8cm or so headroom for the brackets to fit into.
Is there anything available off the shelf to do this?
So I want 4 drives mounted on the floor of the case internally.
