3 fan options for big purchase this evening, which ones for H105 cooler
26 Sep 2013
West End, Southampton
Hi guys, I'm just about to pull the trigger on my next build, a Corsair 780t, H105 and fans for push/pull. There are 4 different SP fans listed to buy, which ones would do a better job in push/pull config? bearing in mind, i need to keep noise to a minimum as PC is in lounge.
So both sp on both sides of rad for push/pull?
And Thx guys, there are so many sp120 fans described as pretty much the same. Whats the difference in quiet series high pressure low noise and the other low noise high pressure?? Different price but equally described as doing the same
If you are talking about the Corsair SP120's then the main difference is speed as you can see from the spec's below this in turn provides a difference in airflow.
Corsair SP120 Quiet Series High Pressure Low Noise
Operating Voltage: 7V – 12V
Airflow: 37.85 CFM
Static Pressure: 1.29 mm/H20
Sound Level: 23 dBA
Speed: 1450 RPM
Power Draw: 0.08 A
Corsair SP120 Performance Series High Pressure
Performance at 12V
Airflow: 62.74 CFM
Static Pressure: 3.1 mm/H20
Sound Level: 35 dBA
Speed: 2350 RPM
Power Draw: 0.18 A
If you are going to use profiles or a fan controller you could buy the higher speed fans and run them at 50% this would give you some head room ?
Ah ok ... these are the same design of fan blade so yes they do perform the same in terms of air pressure the difference here is that the top linked ones are PWM fans and are ideal for plugging into a Motherboard that has PWM fan control as this allows you to use software to control the fan speed in relation to temperature.
