3 Fans per channel possible?
17 May 2007
N Yorkshire
Hi guys, does anyone know any fan controller that let me connect upto 3 fans per channel? i been try to work out the max load on some of the controller, and most seem to have a max amp of 6W/1A per channel, which mean if i using something like the Enermax cluster 120mm fans at .40A then i can only connect 2 of those per channel, and with a controller that had 30w max per channel, is that mean i can connect 5 fans per channel?
Regards
Tony
Lamptron Fan Controller FC5 is what i have and ive got 6 Enermax Magmas on on channel running ok ,you can get fan controllers that have 60watt per if you need it.
Aye, thingemajib's right, so:
Regards
Tony
Well, rearranging the old equation, a 30W channel at 12V gives:
P=IV . . . thus I=P/V.
Plug in the numbers (P=30 W, V=12 Vdc)
I=30/12
I=2.5 Amps per channel
So, in theory, if you are using the 0.4amp fans you mentioned, you should be able to run a maximum of about 6 of them (2.5 amps divided by 0.40 amps)...
(since 2.5A/0.40A = 6.25)
But remember that fans need more juice to spin up at start up than they do when they're already running... so 6 might be pushing it a little - if you overdo it, at best the fans may not start and at worst you could burn out something .... but if you only need to run 3 of those 0.40amp fans on the 2.5amp channel... it should handle that ok.
If their RPMs aren't monitored by the mobo or controller, your best bet is to try starting up with 3... and if it works and you need a fourth, try that... but keep your eye on it for the first dozen or so times to make sure they all spin up, and later on in a few weeks or months when it might have some dust in it, check again that all the fans are still spinning up at startup.
Just be glad you're not running 3amp Delta fans... ahh, the old days of overclocking before watercooling was common. :D
Hope this helps. :)
Thank guys for the help, i only need to run 3 fans for 2 of the channels (for 2 triple rads), just want to make sure i don't overload anythings, i did get a Lamptron Fan Controller FC5, but the buttons on my doesn't line up, so was not so happy with it..
Regards
Tony
I=30/12
Hope this helps. :)
Thank Stickman for the Equation, that will help me work out how many fans i can have per channel when im choosing a fan controller, Big Thank matey...
Regards
Tony
