3 from me - IR's
Caporegime
1 Nov 2003
Lisbon, Portugal
Hi all,
I've been wanting to do these shots for sometime now. They are at my sisters horse yard, to get to where her horse is during the day you have to walk through some fields.
So I've been waiting for a nice clear sunny day and here we go, I'm not 100% happy with them, it's been almost a year since I've produced an IR so I've had to learn it all again.
Please C&C :)
1.
2.
3.
Thank you :)
I prefer the 3rd one out of the three. Although I do prefer some of your earlier work (some of the inspiration for me to give IR a try). There doesn't seem to be enough white in there that you see in IR photos. Think someone commented on my IR entry to the 5 second comp saying there was too much blue left over hinting that my initial IR shot for the white balance was underexposed.
Yes I know what you mean...not enough of the snowy look :)
I will reprocess these hopefully later tonight
They are a bit dark....may be expose a bit longer?
Exposures were for 30 seconds, any longer and I need a remote, problem is (as I discovered) if I up the exposure/brightness any more it makes them look horribly overprocessed :(
Then you'll need a remote :)
£4 from the bay for a 3rd party one.
Even ISO 200 would be a massive increase.
ISO 100 was rarely used in film, its more a studio speed. The general film for outdoors use you'd buy was ISO 400. Shooting at ISO 400 more commonly will allow for greater depth of field in your photography at hand held speeds.
Of course thats no issue here as you are on a tripod but the timer would be a fantastic buy.
Well I've got until its no longer sunny, so a few days. I'll try and go back tomorrow :)
That were me, and yes indeed :D
As a workaround, desaturate, then lighten the blue/cyan channel perhaps. Not sure it will be great, but it wouldn't be blue :D
