3 individual screens
28 Nov 2013
Hi
I have 3 screens running as an Eyefinity group on MSI 7970.
Can i configure it so each screen is separate, 1 running my email, 1 running a game and of coarse 1 running overclockers.
R
I do a similar split only problem is you can't mouse out of the game to another screen without minimising it. (Or at least idk how to).
Just run it as an extended desktop and use ultramon to control what opens where. Can set which monitor the games open on.
Programs should snap to fit screen anyway.
Easiest way I ever found:
Press Windows+P together, select Extended. Go into CCC, disable Eyefinity Group (if currently enabled) and use CCC to set up your three screens as separate and in the right relative positions.
Now press Windows+P again, select Duplicate. Go into CCC, set up your Eyefinity Group.
Now you simply use Windows+P to move between 3 separate screens (for productivity) and 1 huge screen (for games) with only one keypress combination. :D
Note, this only works if ALL your screens are in your Eyefinity Group, otherwise you can use Profiles in CCC to move between preferred setups (I have to do this to move from 4 separates to 3+1 for gaming).
