- 25 Apr 2020
Hi all
I've been tearing out what's left of my hair for many months on and off, with this one. My system intermittently (always from cold boot, 50% of time from warm boot) gives me 3 long beeps, but then still POSTs and boots successfully. However, this only happens when I use the dual channel DIMM slots, and when XMP is enabled.
I know the 3 beeps generally point to a RAM issue, however I've done a lot of testing and found as follows:
1 stick of RAM in any slot is fine
2 sticks of RAM in single-channel mode are fine (even if XMP enabled)
2 sticks of RAM in dual-channel mode are fine if XMP is disabled (i.e. RAM running at 2133MHz)
2 sticks of RAM in dual-channel mode, with XMP enabled - issue as described above.
By process of elimination, I RMA'd my original Viper 16GB 3733MHz RAM, but the replacement stuff they sent was the same. I also recently bought 32GB of Crucial 32GB 3200MHz, and this gives exactly the same results. Default vDIMM for both RAM is 1.35v, but on both cases I tried upping it to 1.4v, again no improvement.
At this point I'm guessing you're thinking faulty mobo (I would be too). However, a few months ago I bought a similar, but not identical mobo (MSI z370 Tomahawk, as opposed to MSI z370 PC Pro). Again, exactly the same issues with the replacement board.
So at this point I'd just welcome any thoughts on this head-scratcher. The best I can come up with at the moment is there's just some issue with MSI z370 boards running RAM in dual-channel with XMP profile enabled. I've thought about trying a different brand of z370 board to see if it's any better, but other than that I'm all out of ideas.
cheers
Danny
cheers
Danny
