- 8 Aug 2009
I have a spare ati x1550 graphics card and i was wanting use a three screen set up.
At the moment i run a 4870x2 with the extreme cooler so this covers my second pciex16 slot.
I'm running dual monitor setup 24" main with a 19" second display with extended desktop enabled.
1st , If i put the x1550 in the bottom pcix8 slot but i wont be cross fireing will it slow the first pci x16 with the 4870 x2 to pci x8?
2nd ,Will i be able to extend my desktop to the 3rd monitor which will be plugged into the x1550 or will it come up with its own task bar duplicating the 24" monitor connected to the 4870 x2.
So what I'm after is the 24" in the middle with the task bar and then 19" monitors on either side where i can extend my desktop to. Will be used for editing photos.
P.S. running windows 7
Cheers
Cheers
