3 monitor setup for under £600
10 May 2009
Hi can anyone advise me on the best monitors for a 3 monitor gaming system for under £600.
Im leaning to 3 BenQ G2420HDBL
The monitor i have now is a Samsung Pebble SyncMaster 2232BW
the res is 1680 x 1050
i know the Benq has a higher res but is it a better monitor overall
Thanks
Thanks
Why not just buy a local picture house ha! then you can play games on a massive screen with Qud sound ha!
Id look at the 22" screens tbh, if you go to bottom you can either stretch budget and get 3 x SAmsung 120Hz or 3 x Dell IPS (out of stock atm though) or if you wanna stay under just get the LGs which are backlit, link, and pocket a ton
