3 Monitor Setup (Pictures?)
Don
23 Oct 2005
North Yorkshire
Hi guys,
I currently am waiting to move into my new house and when I do I will have an eye infinity setup but I can't work out whether I should use the 3 monitor stand I have or the individual stands for the monitors. Obviously the former looks a lot better but the problem is the monitors are 24" so the two wide monitors don't turn in much at all.
What is the best setup for having three monitors? Having the two wide ones turned in or just all three flat next to each other? Not sure I will be moving my neck too much with that setup?!
Any pictures and advice appreciated,
thats mine...
put them on a stand, i have 23.5 inch monitors and i have plenty of room to move them around so you should be fine with a decent stand.
Im in same position as you Andy. Going to be moving to a new house with a nice study and will definitely opt for a 3 monitor setup.
Was there a thread about peoples 3 monitor setups? Would definitely like to get some ideas.
Ah so only tilted in ever so slightly, the stand should allow for that.
yeh, dont tilt them too much else you are turning your head to much to look at the far left of the left monitor and the far right of the right monitor.
you would still be able to turn them a great deal (or should be able to) if you put the bezzles behind each other (i havnt done it on that picture), it would decrease the bezzle size too.
