3 monitor setup software questions
28 Jan 2011
hey guys, 2 things..
1) How can I setup my screens so when I go in-game the main centre display is active, and wont cross into the side monitors, I had to turn them off to play CS GO, then back on when back into Windows?
2) How can I setup the monitors, so if I leave for a bit, and turn off the 3 monitors, then return and back on, they remain in the same windows on the monitor? Right now they default back to the main centre one and I need to re position them.
Cheers guys!
I use software called “display fusion” to achieve the second use case, it probably does the first as well, worth a look.
Hope this helps
