Hi, I'm looking into a new graphics card as I need to get a 3rd screen working on a budget so I'd appreciate a bit of help... the GTX 460 was my favorite until it dawned that SLI is needed for > 2 monitors
Currently I'm using an 8800GTX and the three monitors will be 1080, 1080, 720 so theres really no problem with the power, most cards would be a good upgrade, although I would have course like to get the most powerful card for my budget which is £135. I'm not planning to overclock a new card at all
I hope this doesn't offend some people!
1. Would a 6850 be the best AMD card for my budget to get three monitors working?
2. Buy a second cheap 8800GTX and SLI - How would this compare to just getting a new AMD card? What would you rather do?
3. Get a new sandybridge motherboard - Could onboard graphics be used at the same time as my old 8800GTX to power the third monitor?
4. Buy two new Nvidia cards and SLI them, for £140 (£70 each) would this end up being a really rubbish solution?
Thanks!
J
Thanks!
J
