3 Monitors for Eyefinity on CF 6950
24 Jul 2012
I know these type of questions are asked on a daily basis and I have search for good few hours and read through several threads, but I have not found an answer to my specific question and I don't feel confident enough to just make an educated guess.
Currently I am running the following:
i5 2500 + 6gig ram + CF 6950 Rev.1 (shaders unlocked, but not flashed to 6970)
Mild overclocking and everthing is under water.
Firstly, would the CF 6950 actually be able to push 3 x 120Hz monitors?
I suspect it struggle.
If not I would like to outfit a budget 3 screen setup and look at saving for the next gen cards, so could you help me choose between.
BenQ GL2450
http://www.overclockers.co.uk/showproduct.php?prodid=MO-057-BQ&groupid=17&catid=510&subcat=
BenQ GW2250HM
http://www.overclockers.co.uk/showproduct.php?prodid=MO-060-BQ&groupid=17&catid=949&subcat=
I realise I will need a active MINI display port adapter, and I can pick the XFX version up for £18 from another retailer. OC currently only has one for £70.
Must be honest, the BenQ GW2250HM's at £299 + £18 sounds like a winner.
