3 Monitors which card?
18 Oct 2002
Kuala Lumpur, Malaysia
At the moment I'm using 2 x 17" TFTs , but also want to connect my Plasma screen as a third, via VGA cable.
My current card (Nvidia 6600) only has 2 outputs , 1 x DVI, 1 x VGA.
Which card would I need , not too expensive to use 3 screens? Would like to run a media centre on one on them.
2 options...
(Probably more TBH)
The Matrox 3 headed jobbie.
3 x outputs.
Or get a PCI GFX card to run the Media Center one.
(Won't need much horsepower to run it)
Also, if you have an nVidia, get an nVidia PCI card so you don't need to install drivers from differing companies.
