- 10 May 2004
I am replacing a front 120, a rear 120, and a side 80.
Here is what I am thinking;
2 x Akasa AK-183-L2B Ultra Quiet 120mm: 1400rpm @ 18dba @ 44.8 cfm
1x YS-TECH FD128025LB SILENT 80mm: 2000rpm @ 23.5dba @ 30cfm
My computer is loud under load (when fans are at full tilt) and running pretty hot too. Currently there is no front intake, the rear 120 is very very quiet, but not pushing much air, and the side 80mm which I am using as an intake was salvaged off a cpu cooler (its an old akasa I think) and it makes a lot of noise sucking air through the grill when its a full tilt. My gf6800 regularly goes above 80degrees, my cpu idles at 44 and peaks around about 60 under load and system temps are pretty toasty. Incredibly its all pretty stable, but its been bsod'ing a bit recently so I thougth I'd fix the airflow and sort out the temps and hopefully the under-load fan noise too. So I am hoping for something a bit cooler _and_ quieter.
What do you think? Can I do better?
