16 Dec 2009 at 22:12 #1 Muel Muel Soldato Joined 26 Jun 2009 Posts 3,023 Location Sheffield Hi, I have a 3 pin CPU cooler fan, and the motherboard has a 4 pin power header. I've noticed that the 3 pin plug fits onto the 4 pin header, just leaving one pin out, is it safe to run? Cheers!
16 Dec 2009 at 22:20 #2 RJC RJC Don Joined 29 May 2005 Posts 29,086 Location Kent Yes, this will be fine
16 Dec 2009 at 22:23 #3 Muel Muel Soldato OP Joined 26 Jun 2009 Posts 3,023 Location Sheffield Thanking you.
