I cant seem to find these anywhere so i can plug in to power two fans off one connecter also does anyone know if anyone makes a cable splitter for 3 fans to connect too
Plug two of the linked splitters together to power three fans. Ensure you plug the second splitter onto the connector with just the red and black wire though, otherwise you'll get funky speed readings as two fans will be sneding their speed signal to the controller.
I'd also watch out if you are loading three fans on a motherboard header as they aren't designed to take too much load before frying and going pop.
