- 23 Apr 2007
- Cardiff-ish, Wales
Hi guys,
I've got a 3 fan splitter cable (3x 4pin female connector, 1x 4 pin male and 1x 4 pin molex (power) connector. I need to connect a 3 pin fan connector to each 4 pin female connector, then the 4 pin male connector to Scythe Master Ace fan controller. I want to control my 3 fans on my radiator with one controller knob on the fan controller.
Each 4 pin female socket is wired differently (looking straight on):
1 Blue Blank Yellow Black
2 Blue Blank Yellow Black
3 Blue Green Yellow Black
The 4 pin plug is wired:
Blank Blank Green Blue
The 4 pin Molex:
Blank Blank Black x2 Yellow x2
The Scythe socket:
Blank Yellow Red Black
If I connect the Splitter 4 pin lug to the Scythe socket the wires connect as follows:
Scythe Blank = Splitter Blue
Scythe Yellow = Splitter Green
Scythe Red = Splitter Blank
Scythe Black = Splitter Black.
I can't see that this is going to work. Does it sound right to you?
Any ideas?
The 4 pin Molex:
The Scythe socket:
Any ideas?
