3 pin fan
nbkpsycho said:
Or you could save time and money and mod it yourself like what ive just done :p
Thanks anyway ;)
As im sure you've just found out, yes you can mod them. The third pin is just a prm sensor pin, which you would obviously lose if you hook it up to a molex plug. Other than that it works fine.
Yea, seems to work a treat. I have a 92mm gigabyte cpu fan attached to my window now and its cooling my cpu and graphics a lot better than the stock fan. ;)
