I have an Abit IN9 32 max mobo which has a 4 pin connection for the CPU fan.
I fitted a Noctua NH-U12F cooler and fan and this comes with the three pin fan connector . Course this will fit in one of the nearby Aux fan connectors but although that aint good practise it also prevents me from booting up as i get a post error either 8E or 8F . This is purely because there isnt a fan connected to the 4 pin cpu fan connector.
Is there a three to four pin converter i could use or will i have to get another 120mm fan for the Noctua heatsink? The only four pin ones i seem to see are the molex PSU type so im a little stumped at the mo.
Any help appreciated
