1. Disable Hibernation (if you have 4gb ram, the hibernation file will be 4gb on your C: ) you don't need this for sleep mode (which is faster)
to do this, in the start menu, type
powercfg -h -off, then press enter
2. Disable system restore,
to do this, right click computer, properties, protection, untick all the drives
and resize the amount it can use for the 1 point that it creates
Click Start, type 'cmd' right click it and choose run as administrator, now paste this in..
vssadmin resize shadowstorage /On=C: /For=C: /Maxsize=300mb and press enter
3. Run Disk Cleanup, (this will remove the hibernation file)
if you've installed SP1, then click start, type 'cmd' right click it and choose run as administrator and type
vsp1cln
this removes the SP1 backup removal files
(about 1gb+)
Also, i highly recommend this tool CCleaner slim http://www.ccleaner.com/download/builds/downloading-slim, awesome for removing temp files
vsp1cln
