3 screens way of connecting.
29 Jan 2010
London
Hi, I had just pick up a 65" 4k tv and now I'm looking for a way of connecting all my displays. At the moment I have 32" tv 1080p as my main monitor with 24" 1080p side monitor and 65" 4k that is behind me in front of sofa. My question is how to have them connected to evga 980ti classified? 65" Is connected with 10m hdmi to hdmi port on graphic card, 32" is connected with 3m hdmi to dvi adapter and then to graphic card, last monitor 24" is not connected at all it has hdmi, dvi and vga ports. What would be the best way of connecting all the displays?
Don't tell us what outputs your graphics card has, that would just be superfluous information. :rolleyes:
I'm not about to google image search to find out something you should have included in the OP.
EVGA 980Ti Classified has 1x DVI-DL, 1x HDMI 2.0, 3x DisplayPort if I'm correct
So 65" TV HDMI, 32" monitor HDMI to DVI, so leaves you with 3 DisplayPort, so HDMI to DisplayPort adaptor/converter?
Thanks guys. I wasnt sure about display port as this is a first time I using one. Will any adapter do? Cheap one for £5? I know its a digital signal so it should work... just making sure...
