- 27 Jan 2005
- Newcastle
I'm looking into buying a car in the next few weeks and top of my list is a BMW 3 series, around 2003-2004 but I'm still undicided on what model exactly. It will probably come down to availability and spec but it would be nice to get an idea of running costs and potential problems. I'll be spending around 13k.
330d Sport was originaly the top of my list, from what I can tell it has slightly fewer problems than the 320d but it's not much thirstier. A coupe version would be nice but seems to have a high premium with the 3 litre engine and so it's out of my price range. The swirl valve problem on the diesels worries me a little, is it a big enough reason to avoid them all together?
Looking at fuel costs even though I'll be doing about 20k miles a year, there's not a huge rise in the amount I'd spend on a petrol over a diesel. With mostly motorway miles I'm guessing 35mpg in a 330i is doable and 45mpg in a 330d.... is this remotely accurate?
If so I worked out the difference is about £450 for a year in the petrol but it could be about £1.5k less to buy a petrol version 330 in the first place. Although there's the extra road tax to add for the petrol too.
A 330ci does appear to be available around my budget. I would want a facelift model, Sport version too. Failing that a saloon version would be ok with a good spec and can possibly be had for 1-2k less.
What are the servicing cost differences between the diesels and petrols? And servicing intervals?
I'll be favouring an automatic, if that makes any difference. I'd also have to have leather and as mentioned previously Sports spec.
Is there anything to look out for?
I'll also be considering an Alfa Romeo GT 1.9JTD - Alfa reliability reputation puts me off,
2006-07 Seat Leon TDI (preferably with DSG) a little dissapointed by the dull interior,
Possibly an Audi A4 or A3, would like a little more power from their TDI engines
I'll test drive all of these cars probably but the BMW's are my favourites at the moment. I've even considered the Z4 but insurance quotes were around £1600 for a 25 year old with 3 years no claims, which is more than I think is sensible to pay.
Edit- Almost forgot, what year did each of the 3 series models get a facelift? The coupe's seem easy to spot, very obvious exterior changes, but the saloons I'm not so sure on. Some seem to have Sat nav on the lower portion of the center console, yet others have in the the middle of the center console, is this part of the facelift/engine changes? or a later upgrade?
