3 Sticks work but not 4?
17 Jan 2012
Hello
System Spec;
Mobo: 900FXA-UD5
Memory: Avexair 2666Mhz x2 (Slots 1 and 2)/ Avexair 1600Mhz x2(Slots 3 and 4)
CPU: FX8530
GPU: 770GTX SLi
I got the 1600Mhz RAM today, I can install 1 of the two and the machine boots up fine. I'v tried both sticks in the 3rd slot and they both work so its not a faulty unit.
I can't think of what it would be, any ideas :3 ?
Are you trying to run the 1600mhz ram at 2666mhz? Also your configuration will be wrong if you are correct in your op. I would put the 2666mhz ram in slot 1 and 3 and the 1600mhz in slot 2 and 4 not as you have described above.
