3 to 4 pin adapter
17 Apr 2010
Hi,
My Phanteks PH-TC14PE came with a 4 pin PWM adaptor to connect into the 3 pin plug so the motherboard can control the RPM's on the 2 supplied fans.
I then purchased a 3rd fan for the cooler (Phanteks PH-140TS), this also came with a 3 pin plug, but I have no 4 pin adapter for this, so it's currently running at it's 12v setting.
Does anyone know where I can buy a 3-4 pin adapter so I can run via PWM.
I am struggling to find a reliable source on this, evidently it is possible but everywhere I look seems to show overly complicated workarounds / state it's not possible and I need to buy a fan controller.
Thanks,
Chris.
Contact Phanteks customer service. My guess is they will send you one of their PWM adapters free and/or another "Y" splitter to use on you TC14PE.
Tealc can make one but you don't need a custom unit.
