- 24 Jul 2009
Hi all,
Im looking to purchase this http://www.amazon.co.uk/3-WAY-AUDIO-VIDEO-INPUT-SELECTOR/dp/B0007XQA9U
I currently have my PS3 set up to my monitor and working fine, the next step is sound. So my plan is to connect the PS3 via AV/out to this device, then connect my headphones to it.
Now what I want to know is will it be that simple, my Headphones are a standard affair, they have a mic and a Speaker plug, or they can be used via a USB Dolby thing. I'm currently just wondering if it will be that simple or if im going to need some thing else to make it work.
As a note using Speakers is not an option,I have to use headphones.
Thank you.
Thank you.
