If you do go for Surround+Accessory just check out the Surround configuration guide for your card on the NVidia website. It shows you which monitor needs to be connected to which port.
I will go with the same setup you have
3 dvi and 1 display port as accessory monitor
Cheers
Make sure you get a DP to mDP cable and that your accessory monitor obviously supports DP.![]()
Cheers will that not be what Dell supplied with my Dell 2412m
.Not sure.
My monitors only came with DL DVI cables.
If anything they'll provide a male DP to male DP cable rather than a male to male mDP -> DP cable but I don't know if Dell are more generous with cables.
Hi Rusty0611
Is this what I need?
StarTech.com Mini DisplayPort to DisplayPort Adapter Cable - Video/Audio Cable - Mini-DisplayPort (M) - 20 pin DisplayPort (M) - 1.8 m - Latched
