- 25 Sep 2012
Planning to drain the V12 after finding out the Aurora fluid is not meant for long-term and would appreciate some advice on fittings that would allow easy drainage in the future.
Is there an equivalent of a 3-way tap, preferably for use with XSPC 7/16" ID [16/11mm] tubing?
