3-way tap
25 Sep 2012
So the plan to transplant the innards of the Obsidian into the Carbide 540 is taking longer than expected because in a moment of weakness I splurged on a 1080... and a mobo, RAM and new CPU. These should be arriving next week but having already realised how much of a faff acrylic tubing is I want to make future drainage and washouts as pain free as possible.
Essentially, I want a 3-way tap or connection for 13/10mm tubing and ideally matching the blue Primochill revolvers I already have.
Any suggestions?
Thanks.
Some of the Bitspower fittings I've found on the net that match my needs are 10/14 whereas my tubing is 10/13. As much as I like to think that a mm wouldn't matter, I'm worried that it would given that the whole thing has to be watertight.
Anyone using 10/14 fittings with 10/13 tubing?
