3 x 4k screens as 1 display
13 Dec 2003
UK
Hi
looking to either build a mini / compact PC or use a NUC or similar to achieve this
not going to be used for gaming, just video, productivity
is there an all in one compact mini pc with 3 x HDMI outputs that can achieve this, seen a few with displayport, hdmi and usb c (alt disp) but prefer something with just 3 HDMI to save using dongles etc
if there isnt, what sort of spec would be ideal, something like a low end Ryzen 4xxx series CPU? and what sort of GPU (ideally with 3 x HDMI)
budget up to £500
cheers in advance
Apparently the SZBOX GK (N5105) has 3 hdmi outputs. Not sure if it's going to be powerful enough for you?
If you go the self build route, Asus do a passive graphics card with 4 hdmi outputs "ASUS GT730-4H-SL-2GD5"
DisplayPort can be passively converted to HDMI with a cable. 3 DP should work fine for HDMI monitors.
That said, not sure all 3 outputs would work at once on a NUC or similar, YMMV depending on the motherboard and chipset implementation.
