3 x 5.25" bay 120mm fan mount
5 Nov 2010
Hertfordshire
Wasn't sure whether to put this here or in the case section, but mods please move if needed.
I'm looking for a 120mm fan mount for 3 x 5.25" bays on my NZXT H2. It can't be the Silverstone CFP51 because it sticks out too much and the Lian Li BZ-502B doesn't seem to exist anymore :( . Also, i want it to look clean and be efficient, i'm not suspending a 120mm fan with cable ties etc lol.
Any other recommendations? Surely there should be loads of solutions for such a thing?! :confused:
OK I had found the Lian Li bit quoted above for £22 and change, but if you are happy no probs.
Have sent trust
Thanks Andy, i ordered from there an hour ago, but i got the Silverstone CFP52B :) looks good and also cheap. I'll take out the hotswap parts and leave just the cage and the fan. The fan caddy is wireless as well, so it works just like the NZXT H2 front fans.
