3 x 8pin PCIe Cable mod recommendations for 7900XTX + Corsair HX1000i
4 Nov 2022
El Mundo
I've just been browsing the custom PSU cable section on the OCUK webstore and I'm a bit lost at the moment and wondered if anyone could give some advice?
Basically I'm upgrading to a 7900XTX and would like to neaten the 3 x 8pin PCIe cables up a bit.
Can anyone suggest a good brand/type that's compatible with the Corsair HX1000i?
Thanks in advance.
I used cablemod extensions with 24pin cable combs with my MSI SUPRIM X on a corsair rm850x.
Sorry - a bit late if you've already got what you need, but there are places that do custom cable harnesses *including* bridged 8+8+8 PCI-E, which is a very nice, tidy solution.
