3 X Monitor Setup
25 Oct 2007
Los Angeles
Hi Guys,
I recently purchased a 30" Dell and I want to add 2 X 19" monitors in portrait mode on each side of the Dell. I have a GTX480 however I'm planning to upgrade in the future (it's fine for gaming at present).
The 2 X 19" monitors are mainly for work, development. My question is, what do I need to support this many monitors. A secondary question is that I have a new Lenovo T410 that I would like to use in this setup. It has a display port, although I'm not sure if it's powerful to project a shared desktop given the res???
Any advice from someone who has put together a setup as above would be much appreciated.
Hi there,
With a GTX 480 you will need a second graphics card to run more than two monitors. Since it is for work then a cheap nvidia card (so there are no driver conflicts) like the GT 520 or GT 430 would be a good bet.
As for running your laptop with many monitors - I think you shouldn't have much problem running two external displays (Displayport + VGA) but any more than that would be very difficult since one of the monitors you are running is such high resolution (2560x1600).
Displayport will do a 2560x1440 res, don't quite understand what you mean with "project a shared desktop" but any 2d work will work on any video card no problem, videoplayback etc should be fine as well.
Thanks guys. I think with the 3007 I'm quite limited. Reading around I think I need one of these.
I think that will cover Laptop -> Dell 3007 @ 2560 X 1600. The only issue is regarding multiple monitors.
I think your saying that I will need 2 X graphics cards to cover each monitor? I'm assuming that it would be impossible to connect all three monitors to my work laptop?
Aye, that would be the adapter to go for - Apple also do a DP to dual-link DVI active adapter.
I think you could also connect a second monitor via the VGA (D-sub) connection, but I'm not sure in the laptop display could be used as a third display in this arrangement.
Yea, Nvidia graphics cards (apart from a few special ones) only allow you to connect up two monitors per card. Therefore if you want to connect up three monitors then you will need a second card to drive the 3rd monitor. It doesn't need to be the same model as the main one or run in SLI - just needs to be from nvidia (not AMD/ATI).
