£300-£400 base unit spec?
17 Mar 2004
Hi all. After a new computer so I can put this current one in another room.
Just after a base unit as I have monitor, keyboard and mouse. Also got a M-Audio soundcard to put in, and a copy of XP.
Would 3-400 get me anything worthwhile? I won't be gaming - mainly web design/music editing.
If so could I have some options please - been out of the whole PC loop for a couple of years now.
Cheers for the help!
Cheers. Is there any need for that graphics card though seeing as i'l be doing 0 gaming?
Would also need a hard drive in there.
If not gaming, how about...
  • Abit NFM2-nView nForce 6150 Micro ATX (Socket AM2) PCI-Express DDR2 Motherboard £59.99
  • AMD Athlon 64 X2 Dual Core 3800+ 2.00GHz (Socket AM2) - OEM £54.99
  • Arctic Cooling Freezer 64 Pro CPU Cooler (Socket 754/939/940/AM2) £13.99
  • NEC AD5170 18x18 DVD±RW Dual Layer ReWriter (Black) - OEM £16.99
  • GeIL 2GB (2x1GB) PC5300 667MHz Value DDR2 Dual Channel Kit (GX22GB5300DC) £99.99
  • Antec NSK4400 Mini Tower Case - 380W SmartPower PSU £42.99
  • Samsung SpinPoint P HD080HJ 80GB SATA-II 8MB Cache - OEM £25.99
  • Sub Total : £314.93
  • Shipping : £9.95
  • Vat : £56.85
  • Total : £381.73
:cool:
That does sound nice.
Would it offer a lot of performance over the following:
Asus Vintage AE-1 Barebones system
AMD 64bit 3200+
1GB Samsung PC3200 RAM
AMD 64bit 3200+
Definitely! CPU is dual-core & 2GB RAM to play with :eek:
Will_3rd said:
Slightly over budget
The E4300 is a Core 2 Duo = dual core and also will have 2GB of RAM to play with, will also probably run cooler and more stable than the AMD X2 3800+, also will equal or better it's speed.
tHe_HyBrId said:
{snip}more stable than the AMD X2 3800+{snip}
WTF? :confused: :mad:
For what he needs it for, the AMD spec is more than enough & within budget!
But, if you can stretch the budget then go C2D, but E6300 & above :cool:
