Its limiting I know, but you lot are pretty good.
I did have a spec for £300, but with the new HDD prices (which IMHO arent fair until the companies have to pay higher to get stock it, right now theyre profiting on a disaster), I need a new spec.
My cousin has very little income, so an upgrade probably wont happen...so a 1155 socket isnt possible, nor is second hand.
He's going to use it for video editing and mild gaming (might get away with on board).
I was thinking AMD X4 (cheap quad for editing), but now maybe a llano would be best? An i3 might be possible, but see above.
Try and spec a £40max case incase he doesnt like the specced case.
Thanks you
Thanks you
