300D disassembly instructions
15 Nov 2002
Colchester
Does anyone know how to remove the front of a 300d?
My camera's shutter broke last year and I refuse to pay canon £150 to repair it, luckily I now know how to repair the fault myself (a broken pin see http://www.abo.fi/~jskata/300Drepair/) but I don't know how to get the front off the camera. I have removed the back fine using these instructions http://ghonis2.ho8.com/rebelmod2.html but that doesnt really help me.
Anyone have any experience at this or know of any helpful resources other than http://www.syeager.org/300d/uploads/300D_service_manual.pdf
Thanks in advance
Stuart
Fstop11 said:
Is it not just as easy as unscrewing screws and removing data cables..
You might find you will have to de solder something.
There are certainly some components that require de-soldering to get to the back of the shutter but i dont need to remove those.... I need to get to the front which should just be screws and clips
well I eventually got the front off and managed to put in a new pin, however the camera now will not autofocus, meter properly or fire the flash (err 99) - even when i manual focus the camera the pictures are way way out of focus.
So I fixed one problem and caused another two!
anyone have any ideas, asside from sending it to canon along with a big wedge of pound notes?
You may be stuffed dude, would be cheaper just to get a body only 300D :/
My uncles 300D died recently too, it would not even power on! so he's looking to get a new camera too.
You put the sensor back in in the right place? I noticed on that site there are little spacers that go in to align everything.
If you have cocked that up, I cant see it being a hugely difficult fix but if you cant repair it yourself then you are going to have to spend to repair it...
This is my old camera that broke when I went on honeymoon last year and has been sat in a box for 6 months doing nothing - so I figured I didnt have a lot to lose, and could gain a backup/second body.
The sensor hasnt been moved, only the mirror and the flap on the back of it (and all the associated case, cabling etc), I have fixed the original problem where I was only able to get half exposed pictures but I suspect I underestimated the sensitivity of the internal workings of the camera. The flash capacitor discharged on me at one point with a bit of a flash bang so I'm almost surprised its even working at all.
I think I might have to play with it some more - though it would be good to understand how the mirror alignment works
