Hi,
My 3070 founders gets pretty warm, especially during flight sim, max 76/77c but generally around 73-75c. So I'm thinking of undervolting it to keep it a bit cooler and quieter. However looking at a few guides online each of them seem to use different settings so it's a bit confusing...
I was wondering if anyone here has undervolted their 3070FE and if so would be able to give me a quick run through of what settings you used?
Basically I want to just set it and forget, I'm fine with losing a few FPS in order to run the card cooler and use less power. Also I read somewhere that an undervolt can make things unstable, especially in RTX heavy titles, I would rather er on the side of caution and set it so that everything runs stable.
Thanks in advance!
Thanks in advance!
R to that ramble... its definitely worth it in terms of noise/power reduction. Its just finding 100% stability is a tedious process. And even when you think you have it down (no crashes after hours of stress tests and games...) you might still get that BSOD or game crash which makes you think: Do I go back and re-tweak the UV some more? Was the crash because of the UV or was it something else? (enough to make you grab the PS controller and play sofa games sometimes!)
