Thats fairly normal for air but if you have your 3070 cooled by NZXT Kraken it should be a lot lower, my 2080ti with the Kraken X72 doesn't go over 60 degs during gaming
Does the block need an adjustment maybe, or not enough/too much paste?
Ah ok, i was confused, thought you had the GPU water cooled with the Kraken.
85 is fairy normal for an air cooled GPU although its higher than i would be comfortable with.
I would check your case air flow and ensure there is enough exhaust airflow, sounds like you could have some positive pressure in the case which needs to be removed.
*Terrible* case for airflow, hence your answer
NZXT really do need shooting for that.
I have a fairly similar case and removing the glass/plexi covers will improve temps quite considerably but will be more audible when the fans kick in.
A Kraken G12 to water cool your GPU will be so much quieter and cooler.
Then you reap what you sow dude, good luck
(I'd undervolt it and leave it be until you fancy a change tbh)
its only under gaming which is a few hours twice a week, its cool and silent in normal use. sadly no other cases took my fancy.
This 3080FE runs at 65 Celsius on air when gaming, that's in a full tower case though.
That said, I'd not be happy with 85C at all. But I notice the software is reading just one fan, are both fans on the FE on the same controller? GPU Z shows two separate fans on my system so I'm presuming they each have a controller, but your screenshot only shows one?
i will try gpuz, its only under Warzone does the heat kick up
