3080 FE, more voltage / power limit possible?
6 May 2009
This is my 3080 FE hitting 58c max (but 100% fan)
Sure there is more in it if I can provide more voltage or increased power limit as the default temp limit is 83c.
All system fans are on 42% so could get it quite a bit lower temperature wise still
It must sound horrendous those fans at 100% :p
But I don't think there's a way to increase the power limit short of shunting the resistors since you cannot flash non FE BIOS to FE cards. But your FE is better than mine at least - can only get about 18700 GFX score even under water :)
Oh yes, of course. I would never run at 100% fans but was interested to see after someone posted a 3080 TUF score of 18,936. Is 'shunting the resistors' a hardware mod?
Yeah it is basically adding more (at multiple points) to fool the card into thinking its drawing less power. I don't think my card is efficient enough to warrant it, probably massively increase power draw for a minor clock bump - my card seems a bit of a power hungry lemon :p
I would probably end up destroying my card
Now with system fans at 100%. 19,184, 54c max
