- 29 Jul 2021
- Thuirso
I think there may be something wrong with my new 3080 Ti. Its a zotac trinity.
Basically i switch my pc on and within 10 mins the fans on the gpu are going mental, then it quietens down briefly before going nuts again. Ive never been one for overclocking and only reason i would install the GPU's software is so i can change the rgb.
Im forced to start the GPU software every time i boot my pc because it cannot function without getting stupidly hot without it and ive had to manually set the fan curves because left in auto its not reliable enough to stop temps climbing.
This isnt right... right? none of my past graphics cards needed this babysitting.
