My 3080Ti arrived today and after trawling the internet for info on 3080Ti water blocks I came up empty handed, so I took a gamble on the EK-Quantum 3080 Vector FE and can confirm it fits without any issues.
I love this waterblock. Looks amazing. Have any pictures of your whole build?
Not surprised it fits like a glove, 99% the same card really.
Did you run the card on air at all? Any coil-whine from it? If so...does fitting the block improve / change that situation at all?
One thing putting me off doing a custom loop now is the amount my card whines. No point going full WC to quiet down the PC if I am still stuck with the whine!
Infact.... the fans at least mask it somewhat.
Dam!My coil whine was reduced a lot after installing the EK block for the 3090fe. However, i think its a gamble. I've had cards in the past that have gotten worse after installing a block and remounting did nothing. My last card the 2080ti, I could hear outside the room with the door closed it got so loud after installing a block![]()
I'm pretty sure it's exactly the same card as the 3080 just with the 2 extra Dram chips.
Only one I have to hand was when I refilled it.
