Just upgraded to a 3080TI from a 2080TI and noticed that the 3080 seems to be running hotter than the 2080. I have the same game with the same res and settings exactly the same as before with a locked frame rate but the 3080 seems to be 5-10°c higher. Surely the 3080 should be running cooler with the same workload as the 2080 did?
Fan curve is exactly the same using MSI and both cards are x3 fans.
2080 was MSI Trio and the new card is Inno Ichill x3.
