Anybody here replaced the pads on the 3090FE?
https://www.tomshardware.com/uk/news/replacing-geforce-rtx-3090-thermal-pads-improves-temps-by-25c
The video calls for Thermalright Odyssey 1.5mm pads, which I have found at our favourite online bookstore.
However elsewhere people call for GELID Xtreme 1.5mm pads as they are more squishy. These seem harder to find in the UK. But said bookstore does seem to stock those too...
Wondering if anybody here has fitted either and can comment? (Or has another suggestion of pads to use instead?)
Did you change the core paste too?
I dont mine, and my only real motivation for doing this is noise. I run it undervolted 850@1845Mhz already to quiet it down.
It seems while gaming I get fan yo-yo, where the fans go from a nice quiet 1100rpm up to a very noisy 1600-1800rpm. This seems to always happen as the VRAM temp hits 102-104. (not seen it go higher) Then it goes back down to 1100rpm, and after a while back up.
The core stays cool, between 62-67 the entire time. Max of 70 after a very long session.
If you have changed the pads, did this result in near-silent gaming? (IE fans staying below 1200rpm?)
Thanks!
Thanks!
