Hi,
So I have my 3090 doing a bit of mining with nicehash when idle and I noticed the mining window was showing a warning about "Device #0 is running too hot, performance is degraded" even though its only sitting at 50 degrees.
Ran Afterburner and sure enough, temp is only 50 but temp limit showing 1 there too, same in HWMonitor... what the hell is going on - any ideas please?
Thanks,
Edit, I should add the temp limit/power limit sliders are maxed out at 114% and 90 degrees.
Thanks,
